Re: 1066 Transmission fluid filter
Posted by pete 23 on December 16, 2013 at 17:59:49 from (74.33.91.156):
In Reply to: Re: 1066 Transmission fluid filter posted by Max Walker on December 16, 2013 at 16:33:06:
Most likely reason it will not move when "iced" up or low on fluid, is that the TA is shot in low range (which is driven through a mechanical sprag and does not require hydraulic pressure to pull tractor) and the high range in TA needs hydraulic pressure to lock up the direct drive clutch pack.
Another confusing thing I see on here all the time is people referring to the hydraulic system as hydro . I like to keep the two words separate as to hydraulic systems and a hydrostatic drive. Less confusion.
