Re: Farmall H Clutch stuck
Posted by Farmallman2013 on December 20, 2013 at 07:54:28 from (216.106.244.77):
In Reply to: Farmall H Clutch stuck posted by Farmallman2013 on December 19, 2013 at 22:46:17:
okay the pilot bearing is new, and the disk is in correct because the one I took out I put right beside the one going in, and made sure that it was the same, then I also checked and there is 2/ 32 inch space between the arms and the throw out bearing. could I need a new compression plate? or possibly wait a week of use and it should wear itself down a bit?
