Re: Farmall H Clutch stuck
Posted by old on December 20, 2013 at 08:44:53 from (209.86.226.27):
In Reply to: Re: Farmall H Clutch stuck posted by Farmallman2013 on December 20, 2013 at 07:54:28:
Are you 100% sure you have the correct side of the clutch disk to the flywheel?? You can install the disk 2 ways and if you do not have it in the right way funny things happen with the clutch. Also is the throw out bearing new?? Did you have the flywheel turned so it is flat and smooth??
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
