Re: Help Identify Super A Broken Part
Posted by mkirsch on January 03, 2014 at 05:38:27 from (65.199.189.6):
In Reply to: Help Identify Super A Broken Part posted by rusted nuts on January 02, 2014 at 16:35:42:
Agreed.
That resistor is not even being used!
One wire should be connected at each end. In the picture, both wires are connected to the same end, effectively bypassing the resistor.
Is the tractor 6V or 12V?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
