Re: Broken bolt extractor in engine block
Posted by Red Mercury on January 18, 2014 at 20:38:20 from (204.112.25.232):
In Reply to: Re: Broken bolt extractor in engine block posted by Tom Fleming on January 18, 2014 at 06:20:04:
I agree. I have never had much luck with easy outs and have broken
them before as well. Basically, if the broken bolt is badly seized
there is no way that an easy out is going to break the remaining
part of the bolt loose. All of the other methods of removing a
broken bolt that were mentioned will work with good success. I
usually end up drilling the broken bolt out using a slightly smaller
bit and then try to get the remaining fragments of the bolt threads
out of the hole. Run a tap through the hole to clean up the original
threads and then it's good to go. The trick is to be careful and
precise with the drill.
I read once that a broken easy out can be removed by shattering it
into small pieces with a sharp centre punch. I have never tried it--
has anyone else ever heard of this?
