Re: Baffled over Stanley mufflers
Posted by rustyfarmall on January 19, 2014 at 07:01:52 from (208.126.186.41):
In Reply to: Baffled over Stanley mufflers posted by mkirsch on January 18, 2014 at 16:46:16:
Stanley builds mufflers according to OEM specs. If the original specs called for a baffle, then that is how Stanley built it. If the specs called for the muffler to NOT have a baffle, then that is how they build it. The confusion occurs when folks do not look for the correct muffler for their particular tractor. For instance, the correct Stanley muffler for a Farmall H DOES have a baffle, and the muffler for a Farmall M DOES NOT have a baffle, but the M muffler will fit the H and vice-versa.
My 1940 H has a Stanley muffler purchased from a Case-IH dealer. It HAS a baffle, and it IS quieter. It also has a slightly longer barrell than an M muffler, but the over-all length is the same.
