Re: Farmall h governor
Posted by sony224422 on January 27, 2014 at 11:37:22 from (12.111.44.98):
In Reply to: Farmall h governor posted by Janicholson on January 27, 2014 at 09:47:00:
I'm pretty sure I am timed correctly. What I did to time was rotate the engine to the first mark on the pulley and then I made sure the rotor was pointed to number 1 on the cap. It starts fairly easily, usually with one or 2 revolutions. The carb adjustment I'm not sure if I'm good on. I started at 1.5 for idle and 3 for main. I am going to try and fiddle some more. It's 3 turns out from it being finger tight correct?
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
