Re: Farmall h governor
Posted by Janicholson on January 27, 2014 at 09:47:00 from (74.60.94.18):
In Reply to: Farmall h governor posted by sony224422 on January 27, 2014 at 09:14:42:
Try opening the load screw on the carb one half turn at a time. it sounds like it is lean. If the engine does get to full RPM, the governor is probably not the issue. The mixture and Ignition timing are both critical to power loss.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
