Posted by surveyor33 on February 01, 2014 at 10:36:32 from (108.208.70.188):
Tractor wont stay running after I release starter button. I have already checked switch, replaced starter button.I was told it may a bad resistor. Where is this resistor located? I don't see it anywhere near the coil or in the harness leaving coil. this tractor has the alternator also, not a generator. already by passed clutch saftey switch also. Ran new wire from solenoid to key switch also still no luck .
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
