Re: Zenith Carb Help Needed
Posted by old on February 10, 2014 at 18:26:58 from (209.86.226.56):
In Reply to: Zenith Carb Help Needed posted by labman98 on February 10, 2014 at 17:58:13:
So what have you dine to it that your not telling us?? If you just rebuilt it then the seat may not be tight enough or you have the new rubber tip needle and you need to put a set in the tip so it seals. To put a set in it you drop it in the seat and tap on it a few times. Or you could have a crack in the carb body.
