Re: farmall 300 engine rebuild
Posted by jasinpa on February 21, 2014 at 19:28:04 from (67.234.166.174):
In Reply to: farmall 300 engine rebuild posted by bill gaw on February 21, 2014 at 18:41:20:
never tryed the weld trick on a sleeve but it would probably work, it works great on bearing races , i just made a sleeve pulling plate , used on a 24 inch long, 1/2 all thread w/ a 8 inch puller top, placed on 2 blocks of wood , its crude but works good , also to anyone whos new to these dry sleeves you will have to hone the cyl. after the sleeve is out because of it shrinking over time , they are considered slip fit & when done right they do just slip in there , snug but no big hammer required
