Re: farmall 300 engine rebuild
Posted by Nebraska Kirk on February 21, 2014 at 20:26:39 from (207.91.4.159):
In Reply to: farmall 300 engine rebuild posted by jasinpa on February 21, 2014 at 19:28:04:
Do NOT hone the bore after removing the sleeve!! If you do then the sleeve will be loose. If the sleeve goes in all the way with just hand pressure then it is too loose and you WILL have a catastrophic failure later on. The dry sleeves are supposed to be a press fit, you will be able to push them in 1/3 to 1/2 of the way by hand but you need to press them in the rest of the way with a hydraulic press.
