Thanks for the sketch. Do you know the purpose for the plug that is the side of the the distributor casting? You remove it with a screwdriver. I used to think it was a place to install a grease fitting to lubricate the distributor shaft. I realize now that the hole doesn't go all the way through the brass sleeve that the distributor shaft runs in, so no grease can reach the shaft unless you were to drill a hole in the side of the sleeve.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
