Re: stuck in gear
Posted by tony on December 20, 2000 at 22:14:27 from (156.144.109.24):
In Reply to: stuck in gear posted by tony on December 19, 2000 at 20:54:09:
Thanks for the advice guys. I managed to get the bolt out. It was stuck in there pretty good! I used a long punch and whacked on that bolt in between squirts of pb blaster. I aligned the shift rails, put it together and I'm back in business. I used a newer bolt as a replacement for the old bolt. Do any of you know what the correct size pin should be and how is it retained? What does the freeze plug look like and are they still available? Thanks for your help in getting my tractor back to plowing snow!
Post A Followup
: Re: Re: stuck in gear
