Oil Pressure Gauge Issue - Help Needed.
Posted by farmallhal on April 02, 2014 at 16:46:30 from (76.2.172.199):
Got my Farmall 240 to the point I had it running this morning. Have a small problem with the hook-up of the metal line to the gauge. The original gauge to the tractor opening on the back is somewhat larger then the new gauge I am replacing it with. I'm using the brass connector between the gauge and the pressure line. I believe the hole in the back of the original gauge would permit the end of the pressure line to enter the gauge slightly. The replacement gauge is too small and I believe the tube is bottoming out on the gauge. When tightening the nut against the ferrule I believe I am not getting it seated correctly to the gauge. I might have a problem in that the original pressure line needs trimmed off a small amount so the retaining nut can tighten and seal the ferrule to the brass connector. Or maybe the back of the gauge needs opened up slightly so the line can seat instead of the existing interference on the gauge.
Has anyone run into this issue and what is the proper resolution - gauges are either NOS or obtained from CaseIH. Any solutions or comments are greatly appreciated, Hal.
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
