I do not think Super C tractors had a Key start. It would require a starter relay (solenoid) to be used on the starter, (not hard to do) and a wire from the S terminal on the Key switch to the S terminal on the relay. I have included the diagrams from Bob M which should be correct for a C or SC. The info also covers alternators. A 12v generator system is the same as a 6v. Jim
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
