Re: Case IH Oil Drain Plug Won't Turn Loose
Posted by DeltaRed on April 19, 2014 at 07:57:28 from (65.100.144.27):
In Reply to: Case IH Oil Drain Plug Won't Turn Loose posted by Charles Beaverson on April 19, 2014 at 07:45:29:
In a similar circumstance,I had luck with a pipe wrench. Add air. Find the rated PSI for the tire.You will need a 'water gauge',available from NAPA,etc(NOT autozone....) for about 10 bucks(I just bought one last week).Rotate the tire so the stem is at the top(but not really nessesary) and add air.Just like adding to a car.....
