1. The carburetor is screwed up, and you're screwing it up even worse the more you futz with it.
2. The problem is before the carburetor.
Check your fuel flow! Some crud in the tank, or a plugged up sediment bowl, or a plugged fuel line, or no fuel in the tank, or even as simple as the fuel being turned off.
You should be able to take the fuel line off the carburetor and redirect it into a catch can. It should flow a pencil-size stream of gasoline solid for as long as there is fuel in the tank.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
