756 lifter ticking
Posted by picassomcp on April 25, 2014 at 19:03:02 from (50.124.218.111):
I fired up my 756 after sleeping for the winter
and I noticed a ticking noise coming from the
right side of the engine, sounds like its coming
from just below the head. I'm thinking it could
be a lifter making this noise? I let it run for
about an hour just above idle, the noise is still
there, but that engine sure sounds nice. It
doesn't seem like this lifter issue is effecting
the engine much or at all. Should I be concerned
about this? Do you think it is a lifter? Could it
be anything else? It looks like I can take the
side cover off of the engine to take a closer
look, even taking the valve cover off doesn't look
to hard. I guess I'm just wondering what you
think this noise could be and what you would do
about it if it were yours.
I'm totally comfortable with opening up the engine
if thats what needs to be done. I'm hoping to do a
little moldboard plowing with it in a few weeks.
