Re: Supera ignition problems
Posted by Charlie Seale on May 10, 2014 at 06:48:47 from (66.175.160.75):
In Reply to: Re: Supera ignition problems posted by Janicholson on May 10, 2014 at 06:42:07:
The tractor has set up for 2 years. It was running good when I set it up but I get no fire to the plugs now. when I tie a plug to the coil I get fire but not through the cap. I tried a new cap and got the same results.
