Posted by P T Farmer on May 19, 2014 at 07:27:23 from (173.252.12.221):
Hi there. I'm wondering if anyone has any solutions for a leaking ipto seal. The inside one seems to be riding on the sealing surface ok but the outer seal is riding right at the edge of the smooth surface. Is there another type of seal, maybe a double lip, I can use to make use of more of the shaft surface? Also, how tight should the shaft be inside the retainer cone? There seems to be a lot of movement when its all bolted together. Any info would be great.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
