Posted by gene bender on May 24, 2014 at 18:55:15 from (67.55.226.121):
In Reply to: Governor Rod posted by Bohn Super C on May 23, 2014 at 18:46:05:
Carter carb will be just fine just do a god job on the repair job. How did that engine work with the rod going to the carb so far off are you sure you had the carb open when the throttle is fully advanced or maybe the lever on the throttle shaft has slipped that has happened. Some replacement carbs have that lever adjustable.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
