Governor Rod
Posted by Bohn Super C on May 23, 2014 at 18:46:05 from (174.125.89.90):
third party image
third party image
(Latest Update). I removed the Carter TU Carburetor today on my Super C tractor to clean it and rebuild it. When I tore it apart I found that someone use Rubber Silicone on the Gasket. Then after I installed the Carburetor back on the Intake Manifold I went to adjust the Governor Rod, ( Throttle lever all the way forward and the governor rod moved for wide open Throttle ) with the Clevis screwed all the way out to the last thread on the rod, the rod is still to short. I guess I will have to make a new rod and find the right size Die to thread it.
