Re: Super c camshaft stripped
Posted by White halftrack on May 28, 2014 at 15:35:05 from (174.230.192.207):
In Reply to: Re: Super c camshaft stripped posted by El Toro on May 28, 2014 at 13:28:03:
Thanks for replying. I see used camshafts with the gear on them already for close to the price of the gear. Is the reg c the same as a super c camshaft. Would that be a bad idea?
Thanks again.
