Re: IH 2400b with D179 starting problems
Posted by Charlie Yancey on May 30, 2014 at 09:09:47 from (169.244.32.177):
In Reply to: Re: IH 2400b with D179 starting problems posted by Dieseltech on May 30, 2014 at 07:35:41:
third party image
All I did was line all the timing marks up on the gears. I guess I am a little unclear on the whole timing issue. I aligned them like the picture below.
I made sure the key on the injector pump was at 11 o'clock and thats it.
When the engine is running on ether it does not sound out of time as far as cam and crank, but I dont think I have the injector pump timing correct.
I guess I am in need to a step by step process to make sure I am at 14 degrees.
