Hi, I assume you have the STOP/START/RUN cable adjusted correctly? If you have a compressed air gun, stick the air gun in the fuel tank inlet and take a clean rag and seal around the air gun and slightly pressurize the fuel tank. With all 3 injector lines loosened at rear of pump and with throttle wide open, STOP/START/RUN on START position, attempt to start engine and see if there is any fuel coming out of pump injector ports. Once there is fuel at pump ports then tighten one line at a time while while attempting to start tractor. NOTE: DO NOT CRANK starter for extended periods of time without a cool down period. Also be careful of high pressure Diesel fuel in injector lines.
Also when you do get white smoke out the exhaust and no starting then you may have to rotate the injection pump 1 revolution as it may have been in time the first time and the real problem was no fuel. We have had a 454 since 1974 and have re-sealed the pump 3 times. The only time we had a problem is when my brother attempted to change it by himself. He remove the cap screws on the drive hub without scribing marks. The engine still started and ran but lots of smoke and Diesel slobber.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
