Re: Injector pump problems international 454
Posted by MAH on May 31, 2014 at 17:10:36 from (71.83.74.137):
In Reply to: Injector pump problems international 454 posted by MAH on May 31, 2014 at 05:27:49:
Thank you for your help. I tried what you suggested. I turned pump 1 revolution and I think I have the correct bolt in the correct banjo. Now it still will not start. I am not getting diesel to the injectors on the motor. I am assuming that is the reason it won't fire. It appears to be getting diesel to the inlet banjo at the filter but very little diesel at the inlet banjo on the pump. I also checked the return banjo and no diesel there. I have loosened two of the outlet lines to the motor and no diesel at all. I loosened one line at one of the injectors on top of the motor and of course no diesel there. Before I have to load a non-operational loader tractor on a trailer and take it to a mechanic. Is there anything else I can check myself?
