Re: Super C no spark - changed everything twice still no spa
Posted by Owen Aaland on June 03, 2014 at 19:00:58 from (216.47.33.5):
In Reply to: Super C no spark - changed everything twice still no spark posted by mkirsch on June 01, 2014 at 18:05:24:
The case of the coil is not part of any electrical circuit. Whether it is grounded to the tractor or hanging in free air will not make any difference.
Since you have 12 volts on each side of the coil when the points are open and 0 volts on the distributor lead when the points are closed you know the distributor is working OK. The next question is what is the voltage on the battery side of the coil when the points are closed? We know the distributor side drops to 0 volts but if there is poor connection between the battery and the coil the input voltage of the coil may also drop way down. The voltage at the battery side of the coil should be within a tenth of a volt or so of the voltage at the battery when the points are closed.
