Re: 200 STILL hard to start
Posted by ken house on June 04, 2014 at 08:53:09 from (173.242.240.240):
In Reply to: 200 STILL hard to start posted by clint s on June 03, 2014 at 18:03:59:
you should use copper wire on this tractor. on top of the rotor button, there is a flat spring that contacts the inner side of the coil terminal wire. make sure that this flat spring is in good contact with the terminal post and that both are clean.
