Re: What would cause old tractor to loose power when worked hard
Posted by michael soldan on June 10, 2014 at 11:12:11 from (24.235.39.66):
In Reply to: What would cause old tractor to loose power when worked hard posted by luke0927 on June 10, 2014 at 10:44:26:
Bad coils usually show up when they get hot. Is the tractor running hot? Old engines do lose power when hot,compression as you have indicated,but then you said it has done this from day one so I think I would rule out compression until I did a test on the cylinders.Vapour lock is possible.
