Not sure it has done it since day one, my grandpa probably bought it close to 20-30 years ago from another family member I'm 28 and he's had it as long as I remember. But it has done it for years. But only thing it is used for is a garden tractor just laying off rows, discing weeds etc...and seems like only if your run it a long time.
I have removed the gas cap before when it was doing it did not change as it almost similar like it could be about to run out of gas...it doesn't spudder just idles down...and if you increase throttle idle stays the same (put if you tried to drive when it idles down it will cut off)
I just thought of it but it also maybe more when the fuel is lower say less than 1/4 tank...When it happen yesterday i removed the gas lid to check fuel. I saw it had fuel (but low). When I got home today went and fired it right up and drove it down to the building.
(now this may just be coincidence cause it happens after you run it a while or might be a fuel issue?)
The time before it was lower fuel also actually really low that time. I refueld and that was with 93 and it wouldn't start back up after sitting couple hours I drained the gas and put 87 in next day and it fired up. I've also had to pull it off with another tractor before to get it to start up when it has done this.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
