1953 Cub Want Start
Posted by Gary McArdle on June 10, 2014 at 11:59:15 from (69.179.112.195):
I have a 1953 Cub I've been working on, had a timing problem. It was back firing, it's not backing firing now but when you try to crank it the engine will start to turn fast like it wants to crank but never does. Could I still have a timing problem? I put #1 on top dead center and set the rotor arm on #1 tower on the distributor. Does this sound right?
