Re: Re: Re: Re: Cub Head Gasket
Posted by George Willer on December 28, 2000 at 06:20:57 from (205.133.30.90):
In Reply to: Re: Re: Re: Cub Head Gasket posted by Bill {Antique Acres} on December 27, 2000 at 20:46:58:
Bill,
I guess you haven't seen one of the Cub blocks that were ruined by over torqueing the bolts. The five bolts on the dist side have water passages on 3 sides and the threaded part is only connected to the rest of the block by 3 thin webs! I don't know how much torque the P O used, but three of the threaded parts were pulled out...the block was ruined. 70 ft. lbs? YIKES!
George Willer
Post A Followup
: Re: Re: Re: Re: Re: Cub Head Gasket
