Re: govenor set up
Posted by Jim Becker on December 28, 2000 at 11:02:39 from (208.24.179.208):
In Reply to: govenor set up posted by Pete on December 28, 2000 at 09:29:20:
Linkage:
Engine off, hand control pushed full forward, throttle plate of carb full open. Adjust linkage from governor to carb as long as possible that will allow the pin to go into place without the throttle plate or the arm on the governor shaft moving.
Bumper spring:
Turn in only as far as needed to stop surging.
Fast idle:
Turn cap screw with lock nut in/out to raise/lower fast idle limit.
Post A Followup
: Re: Re: govenor set up
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
