Posted by bja105 on July 06, 2014 at 06:29:48 from (174.130.31.127):
In Reply to: Farmall M, no spark posted by bja105 on July 05, 2014 at 19:09:39:
Ok, I found the points and condenser. I don't think the points are opening. When I crank the tractor, I can not see the points move. Should I be able to see them move?
The square shaft on the distributor has slightly rounded corners, not sharp corners. Should it be that way, or is there a point that that shaft should be replaced? Will new points have enough more meat to the surface that touches those corners that it may work?
I also see the coil says no external resistor is required. That means I can bypass that resistor and send 12v directly to the col, right?
Here are some pics. I had a hard time moving the sun or the tractor, so the lighting isn't the best.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
