Re: Farmall M clutch issues
Posted by D Slater on July 28, 2014 at 04:19:28 from (184.14.185.150):
In Reply to: Farmall M clutch issues posted by HillBillyRockStar on July 27, 2014 at 20:17:00:
If you can get by without the side openings on the reservoir? I have a M with a hydraulic unit gutted with a casting number ending in DD that I use around the place and with the 12 inch clutch. Just use the top and bottom made opening. Used 1/2 inch by 3/4 wide bar steel. Drilled to match the 3 bolt holes in each side of the bottom clutch housing. Then used longer bolts to retain housing and rear cover tin. That clears the 12 inch clutch without finding a late m or SM pump housing.
