Re: C113/123 oil pump cover needed.
Posted by JRSutton on August 07, 2014 at 15:31:22 from (71.174.108.252):
In Reply to: C113/123 oil pump cover needed. posted by PretendFarmer on August 07, 2014 at 07:49:43:
Unless the thing is bent into a C shape - lay down
a large sheet of sandpaper with spray adhesive to
something perfectly flat (thick glass, a large
marble tile, some quality 3/4 plywood - etc.
then lay the cover on the sandpaper and go in a
figure 8 pattern over and over again (without
turning the plate). Flip it occasionally and you
should see a clear wear pattern to gauge your
progress. Very slowly rotate the plate to keep
things random.
- that figure 8 pattern will help avoid favoring
one side.
When you get a uniform finish, you're done.
Probably won't take as long as you'd think.
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
