Re: Farmall C Instant Load When Power Switch Turned On
Posted by farmallhal on August 15, 2014 at 12:01:35 from (50.125.82.123):
In Reply to: Farmall C Instant Load When Power Switch Turned On posted by steamguy14 on August 15, 2014 at 11:39:38:
From my experience that is perfectly normal and I believe it indicates the current to the coil. I'll let one of the electrical experts on this forum advise if the needle indicates the points are closed or open when there is no deflection of the ampere needle. I have seen times when the needle doesn't move when the power switch is pulled to the on position which can also indicate a discharged or defective battery but it is generally the points are either in the closed or open position, Hal.
