Well, I am just about to give up. Used a volt ohm meter and found there were a connection between the ST and the IGN wires without the key being in (low OHM reading). Stuck my hand under the "dashboard" and tried to jiggle some wires to see if any were touching. Put the ignition back in with all the wires attached, but when I turn the key now after seeming to start up normally, it started making a different sound as the starter spun. There was no indication that the motor was actually turning over. The starter armature was moving but the sound was wrong. I am wondering if the contacts on the starter are worn away. However, I have no explanation for the sound change, though the starter is not staying on now unless I have the key in the ignition position.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
