Re: starter motor will not stop running
Posted by old on August 30, 2014 at 14:03:05 from (209.86.226.60):
In Reply to: Re: starter motor will not stop running posted by homebre973 on August 30, 2014 at 09:02:32:
Sounds like a universal type ignition switch to me. It should have a Ig an ACC a BT and a ST terminal on it. The ST is the one for the start position and should only be hot when held that way. Try this. Take the start wire off the solenoid turn on the ignition and be 1000% sure it is out of gear and even better blocked so it can not roll then touch the wire you took off back on to the solenoid. If it spins over when you do that likely to have bad switch of a wire that is shorted together with a hot one
