regulator question
Posted by charlie M on September 04, 2014 at 18:01:27 from (173.87.126.144):
The regulator on my 300U is acting up. Its a 12v, negative ground system with a generator. When I start the tractor the amps go up to a normal reading but sometimes the reading will stay up and if left alone over charges the battery. I can reach down and tap the side of the regulator and it goes back to normal charge. Is this the contacts in there sticking and can they be cleaned and fix the problem or is the problem something else. I've seen this before and eventually it leads to a new regulator.
