Re: 1951 cub quits when hot
Posted by bowman316 on September 05, 2014 at 14:10:11 from (68.33.248.144):
In Reply to: 1951 cub quits when hot posted by bowman316 on September 05, 2014 at 12:23:12:
So I took half the tractor apart, just to get the hood off. then I took the coolant input pipe off the top of the head, breaking 2 bolts in the process.
There is no thermostat there.
And there was coolant down in the bottom tube as well. nothing seems clogged up.
