Re: h4 magneto 180 off
Posted by calcubman on September 13, 2014 at 11:28:02 from (71.102.209.206):
In Reply to: Re: h4 magneto 180 off posted by gene bender on September 13, 2014 at 11:18:34:
the rotor is just before #1 (1 oclock position. when i crank it the mag snaps after the compression stroke is half way down the cylinder.
on another note i did reverse the rotation on the mad from CCW to CW, and i did everything correctly as mag manual states. the mag snaps in the same position on every cylinder just after the down compression or other words the power stroke .. the rotor is at the correct position every time, it just snaps late .
