simple hydraulic question
Posted by Ellis Kinney on September 19, 2014 at 09:58:11 from (74.139.97.108):
I have a 1944 M with the belly hydraulic pump and a Saginaw 3 point hitch with dual cylinders. I currently have it plumbed with one hydraulic line from one of the two hookup fittings on the left side of the tractor. It runs from the pump to the rear of the tractor and then has a tee to the two cylinders. It works flawlessly. However------ would it work more efficiently if I ran a dedicated hydraulic line from each belly pump hookup to each cylinder? Would I increase the volume to each cylinder? Keep in mind that I would have to buy new hydraulic lines and some fittings. Your thoughts please. Thanks, Ellis
