Re: Re: generator check
Posted by REA on January 05, 2001 at 06:55:16 from (209.90.238.63):
In Reply to: Re: generator check posted by Lloyd on January 04, 2001 at 19:09:51:
Hi Lloyd: Thanks I will give it a try. I do have a meter with several funtions, but didn't know if I was using it to the best. Bob
Post A Followup
: Re: Re: Re: generator check
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
