IH 674 ? 2 reservoirs
Posted by John Zitkus on November 07, 2014 at 07:47:51 from (70.196.71.255):
I have a 674 IH with a D239 engine. All hydraulics went down on me
at the same time even second controler for loader, 3-point, stearing
would only allow about a 1 in turn about every 500'. I inched
it to a shade tree to work on it. I figured it must be the pump
so I pulled it and had it inspected, was told it was wore out.
(1972 tractor with oringial pump) Have a new one coming.
The problem worring me now is the manual says it has a 9
gal. capacity, but when I drained the fluid the manual shows
2 drain plugs. When I drained the plug below the pump/filter
I got about 4 1/2 Gal. of fluid, when I drained the forward
plug I only got about 1 Pint of fluid. The oil level gauge (befor
I started) showed was at right in the middle of where it is
supposed to be. Do I have a blocked line to the front reservoir,
which I believe is the clutch housing reservoir. or should I
look for another problem? See attached PDF's
Thank you
John Zitkus
third party image
third party image
