Re: 450 lp will start up but will not keep running
Posted by Centex Farmall on November 14, 2014 at 09:36:10 from (72.105.164.32):
In Reply to: Re: 450 lp will start up but will not keep running posted by rustyrelic on November 13, 2014 at 14:55:08:
No check valve on the intake vacuum. Try taking that line loose from the intake, put a small piece of extension hose and apply vacuum from another source and see if it opens up.
Sounds like the low pressure valve could be stuck or gummed up a little. In that case you'll have to take the regulator apart and see what you have. Two tricky parts on that: One is that the screws my be a little corroded on the threads so take it easy and, Two is peeling the edge of the rubber diaphram off of the housing without tearing it.
  Upload Photo  Select Gallery Photo  Attach Serial No List
