Farmall 400 missing
Posted by Bill in IL on December 22, 2014 at 05:11:07 from (66.94.208.1):
I can't seem to get this one figured out. Tractor has a miss when under no or light loads. Under heavy load it straightens up and runs and pulls great. It seems to get worse as it warms up. I have been through the ignition and carb. I set the total timing with a light cause I wanted to see if timing was jumping around it was steady and set at 25 degrees. I set the valves the other day thinking it would help they were loose and needed adjustment anyways.
  Upload Photo  Select Gallery Photo  Attach Serial No List
