Re: 1943 M engine
Posted by D Slater on December 29, 2014 at 18:35:28 from (184.14.166.249):
In Reply to: 1943 M engine posted by farmboy48 on December 29, 2014 at 18:18:28:
IH power unit and replacement dipsticks were marked on both sides. See if you can find a block casting number up above the oil filter and below the head level. Also see if it has a engine serial number just above the tin cover the breather tube goes to and below the first spark plug. Will be stamped in on the small flat raised area. If its a late enough block the number would be on another raised area under the 2 and 3 spark plug area. If no number found its probably a replacement block. Should find a block date code in the area just mentioned. Also if you find a plate retained by 2 bolts on block to inside of carburetor its probably a replacement.
If a replacement it may have the 43 front cover installed. If the ignition drive casting number has a R1 on the end its a late cover. If not its a 99% probability of a early cover.
  Upload Photo  Select Gallery Photo  Attach Serial No List
