Re: 1943 M engine
Posted by farmboy48 on December 30, 2014 at 17:53:30 from (208.107.15.166):
In Reply to: 1943 M engine posted by D Slater on December 30, 2014 at 16:10:21:
[quote="D Slater"](quoted from post at 17:10:21 12/30/14) farmboy48, unless its something strange that I haven't seen all the cam gears were steel. Early ones had a thinner web from hub out to the teeth.
Did you get aluminum teeth idea from a previous post?
lots of older engines already have the gear change from overhauls or other work over the years. probably the only sure way to tell is to look inside.[/quote]
In the topic about m hydraulics below, Janicholson, posted that the earlier units had an aluminum gear that would strip teeth, or crack the hub if used with a mag/dist pump. I have one on my '50 w-6 that runs a du-al loader with no problem, it was also said that pump did not have enough capacity for the loader. W-6 seems to work fine with a 12 foot JD flex tiller behind it with lift cylinder on it also use it with rock picker. Can I look inside to check cam gear just by pulling distributor shaft housing, or will the front cover have to come off? Gotta get a book....
thanks Dick ND
This post was edited by farmboy48 at 17:55:02 12/30/14.
